We need to select the Registration number for multi select lookup in GER export to GSTR CSV report.
Path: General ledger/Area page/Reports/India/ under the Excise tab we have (GER export to GSTR CSV)
Please suggest me any one
You need to be using SysLookupMultiSelectCtrl for that purpose. For reference see, Class\CustInterestCreate
Moved to Developer forum.
Hi kranthi,
i have already tried. but we are not able to get the lookup.
Please check the below code once if any mistake guide me.
QueryBuildDataSource qbds;
SysTableLookup sysTableLookup;
SysLookupMultiSelectCtrl sysLookupMultiSelectCtrl;
Query q = new Query();
qbds = q.addDataSource(tableNum(TaxRegistrationNumbers_IN));
qbds.addRange(fieldNum(TaxRegistrationNumbers_IN, TaxType)).value(queryValue(TaxType_IN::GST));
qbds.addRange(fieldNum(TaxRegistrationNumbers_IN, RegistrationType)).value(queryValue(TaxRegistrationType_IN::Company));
sysTableLookup = SysTableLookup::newParameters(tableNum(TaxRegistrationNumbers_IN), _formControl);
sysTableLookup.addLookupfield(fieldNum(TaxRegistrationNumbers_IN, RegistrationNumber), true);
// sysLookupMultiSelectCtrl = SysLookupMultiSelectCtrl::construct(FormRun, RegistrationNumber, q);
sysTableLookup.parmQuery(q);
sysTableLookup.performFormLookup();
The second parameter for construct method is the formControl, _formControl.
I have given you an example - \Classes\CustInterestCreate\dialogPostRun
Hi kranthi,
Thanks for your reply. I will check from my side and will get back to you .
