Multi levels Work Order
HI,
I amto able to reproduce a multilevel Work order using NAV 2009 . Is there a bug here?
I have an item that has 3 levels of BOM all of them using MRO as manufacturing policy but when i refresh the released order, only one line shows. what is it missing ?
thanks
Now create a Sales Order and from ther run Order → planning and see ur production order it will show you two lines. And it was same in earlier versions as well. To have it Make to Order u should run through Order it is as simple as that.
YOur main item and lower level semi finished items should have
  1. Manufacturing Policy = Make to Order
  2. Re ordering Policy = Order.
Than only it works.
BTW, I am just imeplementing NAV 2009 and multilevel production orders have been tested. It works fine.
Thanks both of you.
My mistakes : no MTO on all subassemblies items.
It works well.
Then mark it as solved pls, it shows in active topics.[:)]
