Multi-levels group in FA report
Hi everbody,
I want to make a FA report like this:
Name Start Amount Addition Disposal End Amount
FA Class Code 1 0 1500 0 1500
FA Subclass Code1 0 1500 0 1500
Camera 0 500 0 500
Computer 0 1000 0 1000
FA Subclass Code 2 …
FA Class Code 2…
I found the Book Value 01 report and I must modify it. How should I do? Please help me.
Thanks and Regards.
A place to start would be to add a new key to table 5600 Fixed Asset, which consists of both those 2 fields.
Then you have to add the totalling-level to the option string of the variable the user chooses from in the requestform.
In the OnPreDataitem-trigger of Fixed Asset you have to add the new option-value to the CASE-statement, where you set the new key as current key.
Then you have to modify the functions that create the group-header text, group-footer text and maintains the totals.
Here you have to use the Currreport.TOTALSCAUSEDBY function to determine which of the 2 fields generated the total.
The maintaining of the totals might call for a new function, that totals on a new set of decimal-varables regarding the totals of FA Class-level.
Hi
Thank you very much. The groupheader text and body section run well but the total is not. I don’t know how to make a “look-ahead” total. I’ll try more.
Have a nice weekend.
CC
