Mulli selection of values in lookup in AX 2009
Hi Experts,
To complete my customization, I need to write some code that could select multiple values in lookup in AX 2009.
I have seen sysLookupMultiSelectCtrl class that could help me. However, it is not available in AX 2009, instead in 2012.
Any help is appreciated.
Thanks & Regards
Chiranjeevi.
Any class or function or anything that can do???
If the other values can be found from the selected value, you can make one additional select. You need such logic if you allow users to type the value without using your lookup.
Or you can create a custom lookup form, get a reference to the calling form/record from there and set its fields or call its methods. If there is no other way how to specify the other fields, you have to force users to use the lookup to get values.
