Is it possible to link Navision (Any version) to a MS Visio sheet. Apparently Great Plains is able to take a Visio diagram with a Bill of Materials and use that within their system. We need to do something similar.
We’ve been doing some work for a bank related to a CRM solution and have used visio to display entity-client-case links. I wasn’t involved myself but if you e-mail me at rcrick@landsteinar.je I can get you some details Roger E Crick
I assume that it should be ‘simple’ to create a Visio sheet from Navision data. Our need is to send data the other way. Therefore Is it possible to transpose a Visio Sheet back into Navision. ie if a Visio sheet has a Bill of Material sheet, create the necessary BOM in Navision !!!
