MS SQL Query Error
hi,
MS SQL query error from MS Office 2010 excel;
Select ColGroup, Location Code,Description From DB2011.dbo.DB$Purch_Inv_Line
Error message: Incorrect syntax near ‘Line’
did i miss something?
thank you.
Hi Glennyboy,
Could you say a bit more about your problem. Where are yo doing this and what tool are you using in Excel?
Hi Erik,
Thank you for the quick reply.
  • connect to ms sql database from ms excel 2010
  • filtering data before importing from sql database in excel
thank you.
Hi Glennyboy,
Well for a starter then those table names looks wrong. There are no table called Purch_Inv_Line in NAV. Are you sure you’re even connecting to a NAV database? Or is it a custom table?
