I am actually trying to implement the MS Office Smart Tag functionnalities on a PC and I just cannot figure out what I’ve done wrong. Does someone else has been able to setup the Smart tags? Here is what I have done (Navision Database, not SQL):
- My CPU meets all the requirements (Except that my server is a Win2000 pro
- The web service is installed and my directories seems correct
- I am loggued as an administrator to make sure that no security problems occurs
- The ST Integration Toolkit client is installed
- The fob was imported, except for the Codeunit 1 and Form 332
- The Codeunit 1 and Form 332 were modified as described
- The profile.xml was modified with the infos for the server
- The profile.xml was modified with my informations
- The profiles and datasets have been published from Navision in the subdirectories specified (subdir of the virtual dir)
Now, the Navision database server is running , the Application server is running as service (startupparameter=SMARTTAG), the web site is running with the published profiles and datasets, and I still cannot figure out what is missing. Do I have to register some files in the Windows Registry? Do I have to make an action for MSOffice to recognize my changes? If someone could give me a hand, it would be appreciated.
