MS MQ NAS issues!?
Hi!
I did try to run a simple example
http://msdn2.microsoft.com/en-us/library/ms952182.aspx
that wiill show me how to communicate between a .NET appication and Navision.
I get this warning in my Event log
This message is for C/AL programmers:
The call to member OpenReceiveQueue failed. MSMQQueueInfo returned the following message:
Operation dose not support for Message Queuing when this installed in worksgroupmodus.
I did install client, NAS , MSMQ in a single PC that is not member in any Domain,
have i to be menber in a Domain to run this?
Problem is solved,
My call to my privatequeue was worng in Codeunit.
But this is for PublicQueue not Private.
I have a similar error message when I try to run my codeunit (from the same MSDN):
OnRun()
CREATE(MQBus);
CREATE(CC2);
CREATE (XMLDOM);
CC2.AddBusAdapter(MQBus,1);
MQBus.OpenReceiveQueue(’.\toNavision’,0,0); //at this point the error
This error is different, at the end is:
“The Queue not exist or don’t have permission to it…”
Anyone have any idea ? On my local computer it is working fine, but it is trying to run on a W2003 Server SP2 Standard Edition.
Could be .NET version? [:S]
Thank you.
Andras
Nevermind. I know how you can solved this issue. :slight_smile:
There are some of the points in documentation what are not so clear :slight_smile:
You can use the following before you Open a Queue:
OnRun()
CREATE(MQBus);
CREATE(CC2);
CREATE (XMLDOM);
MQBus.CreateQueue(’.\toNavision’);
