Dear all
We are currently using MS Dynamics NAV 2009 R2 (Build 6.0.32966.0) running under Windows Server 2008 R2. Sometimes when users are using the client application it crashes and when checking the local Application Event log I see the following:
Type: System.ArgumentOutOfRangeException
Message:
The added or subtracted value results in an un-representable DateTime.
Parameter name: t
ParamName: t
StackTrace:
at System.DateTime.op_Addition(DateTime d, TimeSpan t)
at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.Reconnect(Boolean timeout)
at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.HandleCommunicationFailure[T](CallServerMethod1 callServerMethod, Exception e, Int32 messageNumber, String sessionId) at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.CallServer[T](CallServerMethod
1 callServerMethod)
at Microsoft.Dynamics.Nav.Client.ServerInvocationHandler.CallServer[T](CallServerMethod1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServiceConnectionBase.CallServer[T](CallServerMethod
1 callServerMethod)
at Microsoft.Dynamics.Nav.Client.ServiceConnection.CloseForm(NavCloseFormArguments& mainForm, NavCloseFormArguments[]& subForms, Boolean force)
at Microsoft.Dynamics.Nav.Client.DataBinder.NstDataAccess.CloseForm(IService service, LogicalForm mainForm, FormResult exitAction, Collection`1 subForms, Boolean force)
at Microsoft.Dynamics.Nav.Client.UIPatterns.NavFormCloseHandler.ExecuteCloseForm(Boolean force)
at Microsoft.Dynamics.Nav.Client.UIPatterns.NavFormCloseHandler.FormClosingCore(FormClosingEventArgs e)
at Microsoft.Dynamics.Framework.UI.LogicalForm.FormClosingHelper.TryClosing(FormClose formClose)
at Microsoft.Dynamics.Framework.UI.LogicalForm.TryClosingThisAndChildForms(FormClose formClose)
at Microsoft.Dynamics.Framework.UI.LogicalForm.Close(FormClose formClose)
at Microsoft.Dynamics.Framework.UI.LogicalForm.Close()
at Microsoft.Dynamics.Framework.UI.UX2006.NavigationService.CloseEmbeddedForm(LogicalForm hostedForm)
at Microsoft.Dynamics.Framework.UI.UX2006.NavigationService.OpenEmbeddedForm(String formName)
at Microsoft.Dynamics.Framework.UI.UX2006.NavigationService.OpenEmbeddedForm(String formName, NavigationNode node)
at Microsoft.Dynamics.Framework.UI.UX2006.NavigateToFormAction.InvokeCore(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession)
at Microsoft.Dynamics.Nav.Client.Actions.NavNavigateToFormAction.InvokeCore(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.Action.InvokeCoreWithErrorHandling(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.Action.DoInvoke(LogicalControl logicalControl, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.Action.Invoke(LogicalControl logicalControl)
at Microsoft.Dynamics.Framework.UI.UX2006.NavigationService.NavigateToNode(LogicalControl logicalControl, NavigationNode node)
at Microsoft.Dynamics.Framework.UI.UX2006.WinForms.NavigationFormAdapter.<>c__DisplayClass5.<get_SearchBox>b__1(Object sender, NodeEventArgs e)
at Microsoft.Dynamics.Framework.UI.UX2006.WinForms.PageSearchBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Source: mscorlib
Has anyone encountered this issue before? Is this an application issue or a network connectivity issue? Users are all on Windows 7. I tried doing a Google search on this but couldn’t find anything related to this issue. What I want to mention is that our version hasn’t been updated with the latest hotfixes/updates for a very long time now.
Any help on this would be much appreciated.
Pierre
