MS Dynamics NAV 2009 SP1 crashes when opening a company
I have MS Dynamics NAV 2009 SP1 client and my database is SQL Server 2008 R2. I have two databases and I use Windows Authentication to log on.
NAV works fine with the first database. But when I connect to second database and try to open a company, client crashes.
Can anyone explain on how to fix this?
Vinod
Is your Menusuite compiled?
What is the latest menusuite you have for RTC?
Did you try by removing if it is 1090?
What about MenuSuit 1090 (Dept - Company) ??
It is 1090 (Dept - Company).
I managed to fixt this issue.
Open the object 1090 in design view. Right click on any of the menu item, and click on assign users. Select the user, compile, close and re-open Navision client.
