MS AX 2012 R2 SSRS report service installation in MS SQL Server 2008 R2 [Developer edition]
Dear all
I am installing SSRS reporting services in AX 2012 R2 with MS SQL Server 2008 R 2 [developer edition].
I am getting error.
Verify that a supported version of Microsoft SQL Server Reporting Services is installed. For more information about which versions are supported, see the System Requirements at go.microsoft.com/…/.
2. Open your browser and verify that you can access the Reporting Services web service URL c1cdt106:8081/ReportServer.
Note: When you use the standalone prerequisite utility, prerequisite checks are run on the current computer only. If you are checking prerequisites for the business intelligence components of Microsoft Dynamics AX, and Analysis Services and Reporting Services are installed on separate computers, the Reporting Services checks will fail on the Analysis Services computer and vice versa. Make sure that you run the prerequisite utility on each computer to make sure that the appropriate prerequisites pass.
For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at go.microsoft.com/.../
IS MS SQL Server 2008 R 2 [developer edition] is compatible with reporting web services.?
