MRP planning for mutiple output
Can Ax Master Planning for plan for multiple output?
Meaning i have a “material sheet” after cut process, it will produce 2 item. 1 is left item code & another is right item code.
Can we setup the above scenario in AX?
Kindly advice. Thanks in advance.
AX as standard cannot handle multiple outputs for a single production. So there is no question of planning…
Multiple outputs for single production can be handled by process manufacturing in AX…
Can you further explain what is “process manufacturing in AX”. thanks.
It is an additional set of modules and funcitonality to handle the requirements of the process industry, like by/co products, it has batch orders, shelf life etc.
