Hi Experts,
I am having FG On hand stock=9 Numbers after runing MRP it is throwing planned production order for 9 numbers(It is not considering oh hand )
FG manufacturing lead time 1 day
Raw material lead time is 45 days
Include on hand check box in master planning is selected
Coverage time fence = 365 Days
Postive days = 365 Days
Negative days= 150 Days
Supply and demand mentioned below
Reference
Requirement date
Req. quantity
Coverage status
On-hand
9
Positive
Sales order
03/12/2011
-1
Zero
Sales order
26/01/2012
-2
Zero
Sales order
26/01/2012
-6
Zero
Sales order
26/01/2012
-1
Zero
Sales order
28/01/2012
-1
Zero
Production
30/01/2012
1
Zero
Sales order
30/01/2012
-7
Zero
Planned production orders
03/02/2012
2
Zero
03/02/2012
6
Zero
03/02/2012
1
Zero
Production
14/02/2012
4
Zero
Sales order
14/02/2012
-4
Zero
Production
17/03/2012
1
Zero
Production
17/03/2012
7
Zero
Production
29/05/2012
2
Zero
Sales order
29/05/2012
-2
Zero
Production
30/05/2012
70
Zero
Sales order
30/05/2012
-70
Zero
Production
07/06/2012
51
Zero
Production
07/06/2012
2
Zero
Sales order
07/06/2012
-51
Zero
Sales order
07/06/2012
-2
Zero
Pl help me in this issue
srinivs
January 30, 2012, 10:03am
2
It will consider your stepups are seems to be correct, but tell how did u run master scheduling only for that item or without selecting any item no in select button.
Rgds,
Srinivasan
Hi Thanks for reply
I am running MRP only for particular item
Sale order lines>Explosion>Update Or
Item>Inquiries>Ner requirement>Update>Master scheduling
Abbas
srinivs
January 30, 2012, 10:43am
4
That your explosion when you run master scheduling it will consider, try running with out any item you will know the results
Srini
Hi srini,
We are running MRP for the single item only, We are not going to run for entire plant.
Abbas
srinivs
January 30, 2012, 11:21am
6
Hi Abbas,
Then check your positive and negative days are lying with in that and coverage group.
Srini
srinivs
January 30, 2012, 11:31am
7
Then check for that item details coverage group or item coverage is defined!!!
You cannot run planning for a single item, filtering the run causes many errors, run it for all and see then if it is correct, running it filtered you have to live with the issues.
Thanks Adam,
My problem has solved by registration of the FG item.
Abbas
srinivs
January 31, 2012, 5:59am
10
Hi Abbas,
Can you explain what you did ?
Srini
Hi srini,
I have done reservation of on-hand stock to the sale order through sales line> Inventory>Reservation
After run my MRP for that FG I have not seen any planned prouction order.
To avoid this problem permanently as Adam suggested I think we need to run MRP for the whole plant.
Abbas
srinivs
January 31, 2012, 6:37am
12
Thanks for your explanation [:)]!!!
