Is there any parameter setup in MRP that production order should not be consider in the planning while bom components will consider ?
Client want to enter Sale Forecast and Run MRP ,System should consider RM stock and FG stock but FG item’s Production order should not be consider during the MRP calculation.
No, basically without the parent there is no need for the components - why do they want to ignore the parent when they are making purchasing decision on the parent? Understanding this question may give you your answer.
