When we set the routing run time in the routing for various opertions for processing particular item and run the MRP/MPS, according the due date requirements system plans the net requirement for all the BOM components along with the Parent item.
As one of the BOM component is used in other parent item for which due date is different a seperate planning line with the net requirement as on that date will be formed for this BOM component with due date as still further in past.
As far as the client’s scenario is there they would like to know the net demand of a particular component by comparing on hand inventory but not as per the system planned dates.
How to achieve this one. Can this be achieved with set up itself or it involves any customisation in coding.
Case Example:
Part A on hand Inventory as on 01/05/09-----------150 No.s
Part Due Date Qty
A 20/03/09 100 ------------------ for the parent item B
A 20/04/09 200-----------------for the parent item C
In the above case, when run the MPS/MRP, system plans the above two lines.Physically inventory is available 150 No.s as on 1st May.
I would like to know by doing any setup can we change the system to plan 50 No.s only when we run the planning as on 1st May.
Thanks in Advance
