Moving active Window
I have been told about an sequence of keys that can be pressed to move the active window if you accidentally ove the title bar out of the screen view. Can anyone remind me of this ??
Hi Dean, I do not know the sequence of keys. But when this does happen I just recompile the Form. (shift/F12 then F11 to recompile)
I had thought of that one… If only life was that simple [:(][:(] The user has managed to move the “Change Company” window which is a form I cannot design. The other problem is that I don’t want to have to delete the zup file as there are loads of other changes been made
Try this key sequence: Alt, <-, arrow down 2x, Enter, and move with arrow keys the company window. This should be performed when Open Company window is just opened.
FANTASTIC !!![:D] [:D] Not the shortcut that I remeber, but it works just as well !!! I also like the fact that it works on ANY active window
This is Windows standard and should work with every application. Hard to find in the docs, but quite useful [;)]
