movement journals erorrs in coding
Hai eveyone ,
i have some problems in this journals can you please correct the erorrs wer i did mistakes in this coding for movement journals
static void createMovJournals(Args _args)
{ InventJournalTable journalTable;
InventJournalTrans journalTrans;
InventJournalTableData journalTableData;
InventJournalTransData journalTransData;
InventTable inventTable;
InventDim inventDim;
Counter cnt;
InventJournalCheckPost journalCheckPost = new InventJournalCheckPost();
journalTableData = JournalTableData::newTable(journalTable);
journalTransData = journalTableData.journalStatic().newJournalTransData(journalTrans,journalTableData);
// Init JournalTable
journalTable.clear();
journalTable.JournalId = journalTableData.nextJournalId();
journalTable.JournalType = InventJournalType::Movement;
journalTable.JournalNameId = journalTableData.journalStatic().standardJournalNameId(journalTable.JournalType);
journalTableData.initFromJournalName(journalTableData.journalStatic().findJournalName(journalTable.JournalNameId));
// Init JournalTrans
select firstonly inventTable;
for(cnt=1;cnt<10;cnt++)
journalTrans.clear();
journalTransData.initFromJournalTable();
journalTrans.TransDate = systemdateget() + 1 div 2;
journalTrans.ItemId = inventTable.ItemId;
journalTrans.Qty = 100;
journalTrans.CostAmount = 100;
// Dimension details
inventDim.InventLocationId = ‘GW’;
journalTrans.InventDimId = InventDim::findOrCreate(inventDim).inventDimId;
journalTransData.create();
journalTable.insert();
// Call the static method to post the journal
if(InventJournalCheckPost::newPostJournal(journalTable).validate())
I
Look at \Classes\TutorialJournalCreateExample
for posting use
\Classes\InventJournalCheckPost\newJournalCheckPost
Post us the problems
