Movement Journal Issue
I have enough stock on my Physical Inventory but while passing movement journal its through error .I have stock movement way only stock arrived no other transaction i did now i am detecting but its coming error like
Check - Journal
Journal: 002942_086
Line No: 1.00
Item number: 90M002
Physical on-hand
Site=S01,Warehouse=COTTON,Lot No.=130562,Serial number=82
168.76 cannot be picked because only 37.76 is/are available from the inventory.
The journal contains errors.
The journal contains 1 lines with errors.
AX surely has a reason to say that only 37.76 is avaialble. Are you sure that you’re taking all dimensions into account when checking the quantity? Isn’t anything reserved?
