MOVEMENT JOURNAL COST
Hai
When I posted movement journal I give cost price 3576.00. After validate and posted item added that group. When I check the financial cost value through Trial balance value added 3576.76. Difference is 0.76 piece. How it is added 0.76 calculated clarify.
Gurunath
Can you check if u have set up miscellaneous charges for the Item?
Was there any previous transaction for the item?
Check the voucher entry of the movement journal transaction. There you may get detail from where .76 value is coming.
Pranav…
No miscellaneous charges.
Negative or Positive entry?
Costing Method?
postive entry
So I guess the answer to my second question which you failed to mention is “weighted average” which is therefore probably your answer.
