move usr layer to var layer
hi all
"i want to move customizations from USR layer to VAR layer"
so i took backup of usr layer customizations thn i renamed the axusr.aod file thn i restarted the service,
am not able to start the services, it getting error msg as
"Reindex of application file failed due to presence of Modified license key in a non microsoft layer"
thn i removed the axapd.aoi files then also am getting the same error.
my goal is want to move usr layer files to var layer,
anyone suggest me some ideas, or help me to solve the above error
thanx in advance
http://msdn.microsoft.com/en-us/library/aa892084.aspx
hi Kranthi,
after moving the usr layer files to var layer, i want to delete the usr layer files.
is thr anyway to do this???
  1. Make a single project of all the customixations on the USR layer.
  2. Export this project to a file
  3. Delete all xpos of this project. doing this will delete the customizations you have done in USR layer, and code residing on lower layers(CUS…SYS) will exist.
  4. change the client configuration to VAR layer, import the XPO.
