I have a requirement . i,e
AOT node->VSproject->DynamicsAxModel Projects-> proj1 is in USR- now i want to move the proj1 to ISV…
what will be the possibility if there is no option for export the USR objects and import them in ISV. . like in AOT node->VSproject->DynamicsAxModel Projects doesn’t support Import. it will throw an error.
please help me
As the USR-Layer is the highest Layer you cannot export the objects and import them in a lower Layer. Export the objects, delete the objects in USR-Layer, add the objects in your ISV-Layer (i think you use the VAR-Layer as ISV). This should work but if you want to be sure try this in your test or development environment befor you use this in your productive environment.
“AOT node->VSproject->DynamicsAxModel Projects doesn’t support Import” - It does. Just press the Import icon or use Import from Command menu.
Hi Tobia ,
Thanks for your reply.
in my case I want to move AOT->VSprojects-> DyanmicsAXmodel project , proj 1 , USR to ISV .
Here I can able to export but, I can’t import . it will throw an error like , invalid AOP tree… so what will be the possibility whether import and export doesn’t work.
HI Martien,
I can able to export the Dynamics ax model projects , but when I am trying to import the xpo ,getting an error message"Invalid AOT\ Tree structure " some thing like this .
Doubt 2:
when I expand the Dynamics AX model project → project output node is empty. seems some .dll should be there. how do I get it . ? but Compilation and Full CIL done with no error.
Do you have any other important information such as that you get an error? Can you provide exact wording of the error message?
Hi Marien,
Here it is …
Critical Error: Invalid AOT path specified
Serious error during import of visual studio project proj1
Import Error at token:(null) line no :0
Actually, I was wrong - you’ll find a workaround here.
You might be also interested in Moving a model to another layer.
