Move File in a Batch
Hello!!
Is it possible use System.IO.File::Move() in a batch in AX2012???
Now i use this method, but file remain in the same folder:(
I try winapi too, but the result don’t change.
help me!!
Antonio
Yes, it is possible. Please debug the batch to see what happens there.
Of course, bother with debugging only if no error gets logged in batch history.
Thanks!!!
Can you tell us what was the problem? Maybe somebody will have the same issue, will find this discussion and would like to get some advice.
