Modifying BOM
Hi, When I try to change warehouse/location in my BOM lines, I face a problem. I am able to change the warehouse but for some reason I am unable to change the location field. It looks like the location field is locked for some reason. The lines in question contains of items from standard dimension group where I have enabled primary stocking against both warehouse and location. Am I missing anything here? Can someone help me please. Thanks in advance, Harish Mohanbabu
Hi Harish, This is by design. It is only possible to edit item dimension (size, color, configuration) and warehouse in the BOM lines. All other storage dimensions (e.g. Location) are disabled. I think it’s because they are too specific to be in the base data setup. Best regards, Vitaliy.
