Modify xml document options
I need to modify the xml document genereted when invoicing customers. The service
name is: SalesSalesEInvoiceService.Read which is enabled thru AIF. The question is
how can i modify - the XML file that the read operation generates. I want to modify the
itemname from the custTrans table and other fields. I thought it would be possible making changes to
the AXCustInvoiceTrans classes (the parm) methods - but it seems that the service does not
use these classes at all (I dont get into these AX tables when debugging)
Any suggestions ?
