Modify sales Header
Hi, I have writen a report, which export datas and which should set a boolean field in the sales header to yes. Although the customer has licenced this module, he gets a message, that he has no permission to modify the header. It is only possible to change this field in the header with the developer licence. Is there a way to do this with the customer’s licence? Thanks
Please search the forum for “indirect permission”. You will find all the info you need to get past that particular error message.
Are you using the same User ID for both licenses? I would assume the the User you are using for the Customer License does not have Write access to the Sales Header Table.
Have you tried to set the property “Permission” of the report explicitly? Click on the Assist-Button in this field and choose the “Sales Header”-Table. Greetings, Frank
