I am using NAV 2009 SP1, I am needing to create a “Super” role but I do not want them to be able to create users or modifying roles. Is there a quick way to accomplish this?
Create a new role, copy the permisions from the SUPER role, delete the last line System, press All objects and filter on Object Type=System, select all, copy, back to the permissions for the new role, paste the System permissions. Finally edit the permissions for System objects 5810 to 5830 as you need.
Thanks for the Tip…
