modifing the table values from code units
hi all…
i want to modify the blocked field values through code unit based on sales …
can u explain with code
The solution is here:
use GET to get your record.
modify field (not validate).
use MODIFY on your record.
This is very simple, so if you’ll need more detailed examples, then I think you rather go back to study mode and read up on Dynamics NAV C/AL programming, before starting this. You should never update fields which are otherwise blocked by the system, unless you know 100% what the effects of such a change is.
Have you check any standard codeunit???
