As my datasource doesn’t contain any date field I added a DateEdit control to Design and wrote some code in it’s modified field so that when i’ll enter some date value the form filters.
By debugging i came to know that it’s modified field method is not triggering at all.
Is there any solution for it ?
The other way of doing it is…
use edit method for the date field.(see InventQuarantineOrder form - showComplete method)
add a range to the data source (based on which you want to filter)
in the executeQuery() method of the data source - give value to the range(the value entered in the edit field).
Thanks Kranti for your quick response.Can u plz explain me in detail.
Actaully i have a form which displays some dates in the grid from the table.
And above the grid dateedit control is there so i want…when i’ll select some date in that date control my form’s grid automattically should filter.
Can u plz tell me " can edit method solve this problem ?" if yes then where i’ll put that ?
create a date variable in class declaration of the form.
TransDate dateEdit;
QueryBuildRange showDate;
Write an edit method like
//BP Deviation documented
edit TransDate DateSelect(boolean set, TransDate _dateSelected)
if (set)
dateEdit = _dateSelected;
yourTable_ds.executeQuery();
return dateEdit;
Add this method to the Date Edit Control in the form Design.
Now in the init() method of the data source add this date field as range
showDate = this.query().dataSourceTable(tablenum(YourTable)).addRange(fieldnum(YourTable,DateField));
in the executeQuery() method provide value to the range before super();
showDate .value(QueryValue(DateEdit));
