I’m logged in VAR layer. I customize a report that has been modified in CUS layer. The modification that are made doesn’t appear to be in VAR layer. In the options I specify ‘show all layers’. I see modifications in SYS, SYP and CUS not in VAR ? So when I export VAR layer I don’t pick-up my modification ! Thanks for answers
Hi Thierry, If the report is modified in the CUS layer, you cannot modify it in the VAR layer, since CUS is above VAR in the layer “order”. I recommend you log into the CUS layer, export the report, then delete the report, log into the VAR layer and import the report from the CUS layer export.
