Models in dynamics ax 2012
i am trying to create a new model through command prompt.
the command i used is… AxUtil create /model:“test_model” /Layer:USR
but it is showing the following error.
The AXUtil command was started in the mode: create.
ERROR: Microsoft Dynamics AX 6.0 not found in the registry. Please specify the /db switch.
can any one help me to get out of this…
thanks in advance…
The registry key with the default AX client configuration is created when you run Microsoft Dynamics AX 2012 Configuration for first time. So run it and try AxUtil again.
Or, as the error message suggests, use /s and /db parameters to specify the server and database to be used.
thankyou martin…
