Hi I’ve the below [Modal Page Handler]
[ModalPageHandler]
procedure SignaturePageHandler(var Signature: TestPage "Signature Pad")
begin
Signature.Clear.Invoke();
Signature.Undo.Invoke();
Signature."Save Signature".Invoke();
end;
I get the error that “The control add-in on control SignaturePad on page Signature Pad has not been instantiated”.
I’m using the control add in signature pad from this Github repository: https://github.com/madearipermadi/ALSignaturePad
The add in contains a “OnControlAddInReady” trigger but when I put a var boolean in the trigger, I cannot access it from a testpage.
Can anyone advise on what changes I need to make to ensure that I can check that the control add in is instantiated from the ModalPageHandler function?
FYI: the original Signature Pad page code is given below:
page 50130 "Signature Pad"
PageType = Card;
ApplicationArea = All;
UsageCategory = Tasks;
InsertAllowed = true;
ModifyAllowed = true;
DeleteAllowed = true;
Editable = true;
layout
area(Content)
group(Signature)
usercontrol(SignaturePad; SignaturePad_Ctrl)
trigger OnControlAddInReady()
begin
end;
trigger AfterSaveSignature(Image: Text)
var
SalesShipmentHeader: record "Sales Shipment Header";
Base64Convert: Codeunit "Base64 Convert";
Outstream: OutStream;
begin
SalesShipmentHeader.Get(PostedShipmentNo);
SalesShipmentHeader."Signature Image".CreateOutStream(OutStream);
Base64Convert.FromBase64(Image.Remove(1, 22), Outstream);
SalesShipmentHeader.Modify();
Message('Image has been saved');
end;
actions
area(Navigation)
action("Clear")
trigger OnAction()
begin
CurrPage.SignaturePad.ClearPad();
end;
action("Update Profile")
trigger OnAction()
var
UserPersonalizationRec: record "User Personalization";
ProfileRec: record "All Profile";
SessionSettingVar: SessionSettings;
ProfileScope: Option System,Tenant;
begin
UserPersonalizationRec.SetRange("User ID", UserId);
if UserPersonalizationRec.FindFirst() then begin
UserPersonalizationRec."Profile ID" := 'NEWPROFILE';
UserPersonalizationRec.Modify();
ProfileRec.SetRange("Profile ID", UserPersonalizationRec."Profile ID");
ProfileRec.FindFirst();
SessionSettingVar.Init();
SessionSettingVar.Company := CompanyName;
SessionSettingVar.ProfileId := UserPersonalizationRec."Profile ID";
SessionSettingVar.ProfileAppId := ProfileRec."App ID";
SessionSettingVar.ProfileSystemScope := ProfileScope = ProfileScope::System;
SessionSettingVar.LanguageId := UserPersonalizationRec."Language ID";
SessionSettingVar.LocaleId := UserPersonalizationRec."Locale ID";
SessionSettingVar.TimeZone := UserPersonalizationRec."Time Zone";
SessionSettingVar.RequestSessionUpdate(true);
end;
end;
action("Undo")
trigger OnAction()
begin
CurrPage.SignaturePad.Undo();
end;
action("Save Signature")
trigger OnAction()
var
Image: Text;
begin
CurrPage.SignaturePad.SaveSignature(Image);
end;
var
PostedShipmentNo: Code[20];
procedure SetPostedShipmentNo(pcodePostedShipmentNo: Code[20])
begin
PostedShipmentNo := pcodePostedShipmentNo;
end;
Many thanks in advance
