Evening all,
Wonder if anyone can assist. I run the code below as a job but do not understand what print (nLoops mod 10) == 0; does. Can someone please explain because I cant work this one out.
static void ModTest(Args _args)
real nLoops = 1;
while (nLoops <= 88)
//print nLoops;
//pause;
// The X++ modulo operator is mod.
if ((nLoops mod 10) == 0)
break;
++ nLoops;
beep(); // Function.
pause; // X++ keyword.
The output I receive when running the code is:
0
0
0
0
0
0
0
0
0
1
I was expecting the raminder to be displayed!!!
And also what does it mean when you change:
to
(nLoops mod 10) == 1;
or
(nLoops mod 10) == 2; for example.
Thanks and kind regards,
Tom
