Misc. Charge in the Transfer Order
How can i add Misc. Charge in the Transfer Order
If this function is not located in AX 2009, What’s the Work Around for this NEED?
Thankkkkks
Hi Mohamed,
What for u need the Misc Charges in the Transfer Order? Do u need to increase the Inventory cost through the Misc Charges?
If so u can go ahead to make the transfer order and then after you can use the “Closing and Adjustment” that is available in the Inventory Management - Periodic.
S. Ananda Subramanian.
Add-ons will allow this, Inventory Manangement II from memory is one of them, but there are more. Standard does not allow this as there is no perceived increase in the cost of the item for an internal movement.
