Not really sure, but if you have not used the item you could put the negative quantity in the receive now and post it to reverse it. Then go to the line, setup, miscellaneous charges, add it and re-receive and invoice.
There will be other ways but you need to speak to a finance person really. The issue here is that the cost has gone through. You could adjust the cost in the inventory close and post the carge as an ad hoc journal.
Yes if you add the miscellaneous charge to the line as I suggested, it is for the item on the line, not all items on the order as with the header entry.
Select invoiced purchase order Go to inquiries > invoice > Misc. Charges, Adjustment you can adjust the Misc charges the system will take care of this adjustment while doing the recalculation…
And the same issue with Kenl above, unfortunately we have sold the item and we can not do sales return on those items, and do a purchase return, then put the misc charge.
Can we make misc. charge adjustment for 1 purchase line only?
