We have a Ax 2012 feature pack production environment with the following build numbers and
Kernel Version 6.0.1108.7029
Application version 6.0.1108.670 (Cumulative Update 3)
solution version 6.1.1108.670
List of installed KBs
(KB2708448) Update balance during the posted process
(KB2717490) Financial dimension set balance rebuild
(KB2724420)
(KB2731469)
(KB2743683)
(KB2771058)
(KB2783578)
(KB2791485)
(KB2809934) Sales Order service doesn’t calculate the ATP requested ship date for sales lines
(KB2818636)
(KB2823955) The inventory value report does not support recurring batch process
(KB2709934) Cumulative Update 3
We want to migrate the system to another Data center. We are planning to first create a AX 2012 Feature pack environment with the blank database and then restore the production database.
Please suggest how can we create the new environment? as application and kernel versions are different and there are many hot fixes have been applied on that.
Can we create an Ax 2012 Feature pack with CU3 and all other hot fixes available with existing system and then restore the existing Database?
or
Can we create an Ax 2012 Feature pack with latest CU (or a CU which has number greater than highest available hot fixes) and then restore the existing database to avoid installation of individual hot fixes?
