hi all,
i am installing AX 2012 with SQL server 2008 R2 database. i started to install Business intelligent components in ax 2012 setup wizard.i successfully installed reporting services extensions and deployed all the reports into reporting server. now the problem is with Analysis service configuration, when i am trying to install this component and it is showing the error in prerequisite validation.
I have installed both components in SQL serve 2008 r2 but i am failing to configuring in ax 2012.how can i resolve this and what might be the reason, can any one suggest me about this error.
thanks in advance…
