Dear Martin,
Check the detail logs below.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Cannot call StartAt when content generation is in progress.
at System.Windows.Controls.ItemContainerGenerator.System.Windows.Controls.Primitives.IItemContainerGenerator.StartAt(GeneratorPosition position, GeneratorDirection direction, Boolean allowStartAtRealizedItem)
at System.Windows.Controls.ItemContainerGenerator.System.Windows.Controls.Primitives.IItemContainerGenerator.StartAt(GeneratorPosition position, GeneratorDirection direction)
at System.Windows.Controls.Panel.AddChildren(GeneratorPosition pos, Int32 itemCount)
at System.Windows.Controls.Panel.OnItemsChangedInternal(Object sender, ItemsChangedEventArgs args)
at System.Windows.Controls.Panel.OnItemsChanged(Object sender, ItemsChangedEventArgs args)
at System.Windows.Controls.ItemContainerGenerator.OnItemAdded(Object item, Int32 index)
at System.Windows.Controls.ItemContainerGenerator.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args)
at System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType)
at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
at System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args)
at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args)
at System.Windows.Controls.ItemCollection.OnViewCollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
at MS.Internal.Controls.InnerItemCollectionView.Insert(Int32 index, Object item)
at System.Windows.Controls.ItemCollection.Insert(Int32 insertIndex, Object insertItem)
at Microsoft.Dynamics.Kernel.Client.UI.WPF.Controls.IndexTab.AddTab(String caption, Int32 index)
at CustomTabWrapperBase.AddTab(CustomTabWrapperBase* , Char* caption, Int32 index)
at CustomTabWrapperBase.OnItemClicked(CustomTabWrapperBase* , CustomTabItemClickedEventArgs e)
at Microsoft.Dynamics.Kernel.Client.CustomTabEventProxy.OnItemClicked(Object sender, CustomTabItemClickedEventArgs e)
at Microsoft.Dynamics.Kernel.Client.UI.WPF.Controls.IndexTab.tabControl_SelectionChanged(Object sender, SelectionChangedEventArgs e)
at System.Windows.Controls.SelectionChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.Controls.TabControl.OnSelectionChanged(SelectionChangedEventArgs e)
at System.Windows.Controls.Primitives.Selector.InvokeSelectionChanged(List1 unselectedInfos, List1 selectedInfos)
at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
at System.Windows.Controls.Primitives.Selector.SelectionChanger.SelectJustThisItem(ItemInfo info, Boolean assumeInItemsCollection)
at System.Windows.Controls.Primitives.Selector.OnSelectedIndexChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
at System.Windows.Controls.TabControl.OnGeneratorStatusChanged(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Controls.ItemContainerGenerator.SetStatus(GeneratorStatus value)
at System.Windows.Controls.ItemContainerGenerator.Generator.System.IDisposable.Dispose()
at Microsoft.Dynamics.Kernel.Client.ActionPaneInterop.ClickEventHelper.Clicked(Object sender, EventArgs __unnamed001)
at Microsoft.Dynamics.Framework.UI.WinForms.Controls.ActionItem.OnButtonClick()
at Microsoft.Dynamics.Framework.UI.WinForms.Controls.ActionButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Ax32
Assembly Version: 6.2.0.0
Win32 Version: 6.2.158.0
CodeBase: file:///C:/Program%20Files%20(x86)/Microsoft%20Dynamics%20AX/60/Client/Bin/Ax32.exe
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Microsoft%20Dynamics%20AX/60/Client/Bin/Microsoft.Dynamics.Kernel.Client.DLL
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Version: 1.4.0.0
Win32 Version: 1.4.11343.16
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Dynamics.Framework.UI.WinForms.Controls/1.4.0.0__31bf3856ad364e35/Microsoft.Dynamics.Framework.UI.WinForms.Controls.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.Dynamics.Framework.UI.Navigation
Win32 Version: 1.4.11064.00
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Dynamics.Framework.UI.Navigation/1.4.0.0__31bf3856ad364e35/Microsoft.Dynamics.Framework.UI.Navigation.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Microsoft%20Dynamics%20AX/60/Client/Bin/Microsoft.Dynamics.Kernel.Client.UI.WPF.Controls.DLL
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
PresentationFramework.Classic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.classic.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
Microsoft.Dynamics.DynamicProxy
CodeBase: file:///C:/Program%20Files%20(x86)/Microsoft%20Dynamics%20AX/60/Client/Bin/Microsoft.Dynamics.DynamicProxy.DLL
Microsoft.Dynamics.Xml
CodeBase: file:///C:/Program%20Files%20(x86)/Microsoft%20Dynamics%20AX/60/Client/Bin/Microsoft.Dynamics.Xml.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<system.windows.forms jitDebugging=“true” />
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Ally
