Microsoft Nav 5.0 crashing
A am an I.T. Administrator for a car manufacturing company called Electronic Motion Systems. I have installed Microsoft Nav 5.0 on a few client machines but at certain places within Nav, Nav crashes out with the following error log:
Log Name: Application
Source: Application Error
Date: 05/09/2013 08:08:48
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: PCSW276.ems.com
Description:
Faulting application name: finsql.exe, version: 5.0.26084.0, time stamp: 0x47b39d56
Faulting module name: finsql.exe, version: 5.0.26084.0, time stamp: 0x47b39d56
Exception code: 0xc0000005
Fault offset: 0x000c4924
Faulting process id: 0xa58
Faulting application start time: 0x01ceaa0555592452
Faulting application path: C:\Program Files (x86)\Microsoft Dynamics NAV\CSIDE Client\finsql.exe
Faulting module path: C:\Program Files (x86)\Microsoft Dynamics NAV\CSIDE Client\finsql.exe
Report Id: 02012826-15fa-11e3-a873-7427ea12b931
Event Xml:
Error">](http://schemas.microsoft.com/win/2004/08/events/event)
1000
2
100
0x80000000000000
44537
Application
PCSW276.ems.com
finsql.exe
5.0.26084.0
47b39d56
finsql.exe
5.0.26084.0
47b39d56
c0000005
000c4924
a58
01ceaa0555592452
This is the error message shown bellow:
This is what the user is attempting to do to get this error:
warehouse, whse recpt lines,
search for item comes up with PO, fill qty to receive
add line item tracking add in lot no. and qty base,
post - post receipt. -
nav then crashing intermittently.
Any help would be appreciated.
Regards
Hi Lee,
A few questions to help us better understand your problem.
What happens if another user try to post the the same receipt? If some users can post while others cannot then there might be a security/permission problem.
And does this only happen on this particular receipt or for all receipts posted by the user? If only this, then you should check exactly what is wrong in the setup of those two different receipts?
Appreciate the quick reply.
If another user of the same machine build - type does this they get the same error and th same crash. Where would the permissions need to be similar on another machine?
I am unable to consistently test this as we are running a live system and users are regularly on their machines.
This issue seems to happen on all receipts, as far as I am aware. The warehouse manager has replied to me stating “This crash happens with any transactions that clash with another user”.
Regards
Further information,
This is from the warehouse manager:
"When saving item tracking on any transaction (item journal, receipts, consumption …).
For example on an item journal when performing a negative transaction we would use LINE > ITEM TRACKING LINES > FUNCTIONS > SELECT ENTRIES……At this point after selecting the entries (lot numbers required ) we would press ESC to move back to the transaction and the lot numbers selected would save. This is when the crash occurs.
Hope this helps.
Joe"
Regards
Hi Lee,
I think that it’s about the time where you have to call your partner to get them to help with this. It might even come down to an error in the application, which requires an update of the build you’re running. But to solve this, then it needs some serious debugging.
Much appreciated.
You’re welcome. We hope (expect) that you’re coming back and tell us what was the solution. [:)]
