Microsoft Dynamics NAV Developers Toolkit is the one, integrated tool that helps Microsoft Dynamics Certified Partners to maintain, customize and upgrade Microsoft Dynamics NAV.
It helps partners work faster and with accuracy, thanks to the direct link between the Microsoft Dynamics NAV development environment and the toolkit. While analyzing or upgrading Microsoft Dynamics NAV, you simply switch between screens as you work. Its well-laid out and color-coded graphical user interface gives you a clear, in-depth picture of all the elements you are working with, application code, and relations between objects.
The Microsoft Dynamics NAV Developers Toolkit, including tools for Source Analysis, as well as a Compare and Merge tool.
Release date [6/3/2007]
https://mbs.microsoft.com/partnersource/downloads/releases/ndtall.htm?printpage=false
