Microsoft Dynamics AX 2012 Management Shell
Can somebody point me to where I can find the management shell 2012? I’ve AX installed but when I try to find management shell I can’t find it. Is it located under Microsoft Dynamics AX Components or Setup Support File?
Any help will be greatly appreciated! Thanks in advance!!
If it’s installed, it should be in Start Menu > All Programs > Administrative Tools > Microsoft Dynamics AX 2012 Management Shell.
Otherwise run AX 2012 installer and install Management utilities. Note that they’re often installed only on the machine with AOS.
