is Microsoft Dyanamic Nav 2009 compatible with sql server 2008 R2?
i try to create a new database but didnt work any idea?
Yes, it is compatible.
Can you provide more details on your problem?
add the xp_ndo_x64.dll to the binn folder. Run the following code in SQL query
USE master
EXEC sp_addextendedproc xp_ndo_enumusergroups, ‘C:\Program Files\Microsoft SQL Server\MSSQL\Binn\xp_ndo_x64.dll’
GO
GRANT EXECUTE
ON [xp_ndo_enumusergroups]
TO PUBLIC
GO
Similarly for
xp_ndo_enumusersids
i try to do this and still not working
when i run the code in sql query it says :" the object xp_ndo_enumusergroups already exist in the database"
Any idea ?
Make sure that xp_ndo_enumusergroups is refering to correct dll…
Make sure it’s in the Master DB and not your NAV DB
