I have an item which has a Production BOM & Routing No. attached to it since it is a manufacturing item. The Production BOM has components as they should be.
The issue is when I create a production order of the item and refresh it, I get one line for the item and a 2nd line for a component of the item which is also a mfg item and has a production order no. & routing no. attached to it.
Earlier I never used to get the 2nd line and I am not sure what is causing this.
any thoughts ?
Vishal
