Method error
hI,
With the below method i need to know how to get the start date
if (ret)
caepr1 =CaePR::find(this.EmplId);
select caeStartDate from caepr1 where caepr1.EmplId == this.EmplId;
if (caepr1.caeStartDate == this.caeStartDate)
ret = ret && checkFailed(“Start Daet already exists”);
Like am always getting the start date as the first field start date from the grid.But i need get the start date from the query
select caeStartDate from caepr1 where caepr1.EmplId == this.EmplId; I dont know how to call it.
Sindhu
I have a table called PR .Here we have employee id and start date.For single employee id ,it should not duplicate the start date.With the above method always it is checking with the first start date of the employee.I want the method to loop all the start date of the particular employee and if the start date exist it should pop a message.
Sindhu
// Find matching record if any
select firstonly caepr1
&& caepr1.caeStartDate == this.caeStartDate;
// matching record found
if (caepr1.recId)
…guys, where’s the point calling a find() method (basically a select statement) and then in the following code lines to do a select with the same table buffer once again? Basically CaePR::find() is called and you don’t even care what it returned, you just use the same buffer for the next select statement.
Thanks a lot for the response.
But i wrote a method to loop the start date.i think it worked.
boolean ret;
CaePR caepr1;
ret = super();
if (ret)
while select forupdate caepr1 where caepr1.EmplId == this.EmplId
if ( this.caeStartDate == caepr1.caeStartDate)
ret = ret && checkFailed("@CAE97");
return ret;
boolean ret;
CaePR caepr1;
ret = super();
if (ret)
return ret;
Yes it works but this is not a best practice. Using a loop with if statement is longer than using a select with several where clauses. Moreover if you just need to check if a record exists, you must select a list of fields instead of the record itself. Write the code bellow without the find() method:
select firstonly RecId from caepr1
if (caepr1.recId)
ret = ret && checkFailed(“Start Date already exists”);
Florent
Thanks Florent .I have changed the code without having while loop.
