Merging with Microsoft Word
I need to add some Merge fileds in Header/Footer level of a word Document. and how could i update them using coding in Navision ?
help me regarding this.
Thank you .
You will need to modify codeunit 5054 WordManagement and add in the fields with calls to the Addfield function in the CreateHeader and ExecuteMerge functions.
HI,
actually i am not using Codeunit 5054 WordManagement.
i have just create a Template and i am going to write it using MergeFields.
using WordDoc Automation.
CREATE(Wdapp);
TemplateName := ‘C:\Name.dot’;
WdDoc := Wdapp.Documents.Add(TemplateName);
//Wdapp.ActiveWindow.View.SeekView := 9;
Wdapp.ActiveDocument.Fields.Update;
//wdApp.ActiveWindow.Fields.Update;
WdRange := Wdapp.ActiveDocument.Fields.Item(1).Result;
WdRange.Text := Customer.“No.”;
WdRange.Bold := 1;
WdRange := Wdapp.ActiveDocument.Fields.Item(2).Result;
WdRange.Text := Customer.Name;
WdRange.Bold := 1;
WdRange := Wdapp.ActiveDocument.Fields.Item(3).Result;
WdRange.Text := Customer.Address;
WdRange.Bold := 1;
Wdapp.Visible := TRUE;
Wdapp.ActiveDocument.Fields.Unlink;
using this code i can abe to add fields and update them at Body Level.
similarly i need to add some Fields at Header level and need to update.
which collection do i need to use for my requirement?
Hello, any solution please…
What’s your reason for doing it this way and not use the standard functionality?
I don’t have idea how to use that codeunit.
please guide me …
thank you for your suppor.
Hi Danda,
Have a look at the standard create interaction - form 5077 - it should give you a good example of how to use the codeunit.
