Merging Add-ons Problem
Hi Guys, We have a prospective customer who is buying a Navision Add-on. The said Add-on is based on the W1 version of Navision 4.0. The issue here is that we need to merge this Navison W1+Add on with our Indian Localizations. Generally for all our merge/upgrades of Hot fixes /SP we just compare the changes and put in our customizations manually wherever req. In this case we cannot consider the Localization as cutomization since our dev. license does not allow us to create the localized objects developed by our NTR. Does anybody have any experience of doing this ? Any ideas on how to do this?
Hi, if no localization exists for your country, you need to reach an agreement with the Solution Center, that has done the Add-On, so that you get a license that allows you to make the localization yourself. regards Daniel
You should be able to just import the objects and then modify them. My license does not allow me to create objects in the localized area, but I can change everything on them once they are in.
