When trying to use the Transformation module of the merge tool specifically
under Transformation Setup when I try to do an “Import Form Type to Page Type Mapping”
I get the message "You do not have permission to run the Import/Export Form Types Dataport.
Contact your system administrator to have your permissions changed"
Other areas have like the compare and merge functionality doesn’t give any problems and I have
loaded my license too.
Does anybody have an idea on how to go around this problem.
