Memory work load problems with finsql.exe
We have following problem: The memory work load of finsql.exe at the NAV clients become greater and greater within a short time until an error pops up (not enough memory). We are using the latest build of the NAV 5.0 SP1 client. Is this only a problem of a “bad” application? A central part of the application is using temporary records. We don’t want to change it because we had reasons to use temporary records at this module. What can/should we do?
You will need a person (developer) to look at this modification and see how you can optimize it so that you don’t run out of memory.
