in a customization job, I make use of 2 different Arrays of Struct, like
/*code snippet
Array = new Array(types::Class);
Array2 = new Array(types::Class);
Array.value(id, new Struct(types::real, “param1”, types::Integer, “param2”));
Array2.value(id, new Struct(types::string, “param3”, types::Integer, “param4”));
first array holds in real 23 values in the struct (23 seems to be the limit in Struct)
So thats why I created a 2nd Array, cause I have more values.
What I experience is that after making a modification and start the code again, some values of the Struct are old values.
It looks like the Structs are not fully cleaned or initialized in memory.
Is this a memory leak?
Is finalize() the way to fix this, if yes how to use finalize exactly?
What can be the problem of this behaviour?
