Hi all, I am attempting to install Navision 4.0 SP1 client on a Windows 2000 SP4 machine. I go into Custom Setup, select Help, MSDE, and MDAC. Setup installs the client, the SQL client, but does not “seem” to install the MDAC. I’ve been running updates to make sure the computer is with the latest Microsoft updates. However, just curious if anyone has a work around. Thanks in Advance!
Do you really need MDAC on that machine ?
Yes it wasn’t letting me into the program otherwise. I did resolve it though…happened to search further into the setup and found the extraction files for MDAC. The user is able to log in now! [8D]
