Hi, While working on MBS NAvsion 3.70 ,when ever i select all the objects from the Object Designer and start compiling, the MBS Navison 3.70 installer pops and goes out after lots of cancellation. Can i get get rid of this?[xx(]. Regards Harikesh
This is due to an installation error. It happens a lot on Terminal server / citrix. If you need to follow this further, please post in the Technical forum. You can also find hundreds of posts on this topic using the search option.
